Pilotage EQ6 Pro via câble USB A - USB 2
Modérateur : JeanJacquesB
BertrandL
Message par BertrandL »
https://www.highpointscientific.com/ast ... th-your-pc
https://youtu.be/NobKVj40LUI?si=cXhu32AMn5G19KQe
Le seul truc c est qu il faut changer le baud rate à 115200 au lieu de 96000
Step 1: Download and install ASCOM. The link should be on the right hand side of the page.
Step 2: Download and Install EQASCOM (Often referred to as EQMOD) from Sourceforge.com. Please note that this is not the first file listed.
Step 3: With everything now installed, it is time to connect the mount. Start by ensuring the mount is set in the "Home Position” (Upright and forward/North).
Step 4: Plug the mount into the PC using USB cable.
Step 5: Connect mount to Power and turn the mount on with the power switch on the side panel.
Step 6: On your Windows Computer, use the search bar to open "Device Manager". Look for the "Ports (Com and LPT)" tab. Find "Prolific PL2303GL USB Serial COM Port (COM#). It will be listed as (COM1) or (COM4) or other possible numbers. Write this COM# down for later use
Step 7: Using the Windows Search Bar, open the ASCOM Device Hub. Select the Tools tab and select Setup. This will open the Device Hub Application and Driver Setup window. Select "Telescope Setup" tab. Under "Telescope Device" click on the "Choose" button.
Step 8: The ASCOM Telescope Chooser window should now be open. Select "EQMOD ASCOM HEQ5/6, then click on "Properties."
Step 9: The ASCOM Setup window should now be open. You will see black and red coloring. Mount options should say "Auto Detect."
Step 10: Adjust the settings of the EQMOD Port Details as follows: Timeout - 1000, Retry - 2, Baud - 115200, Port - Insert the COM# from Step 6 earlier in this guide.
Step 11: The Site Information section can be found at www.websiteforlatlongelevation.com. Use this website to determine the latitude, longitude, and elevation.
Step 12: For Guiding, select ASCOM Pulse Guiding.
Step 13: All other setting can be left as they are.
Step 14: Click the "OK" bar across the bottom of this window. Click "OK" in the ASCOM Telescope Chooser window. Click "OK" in the Device Hub Application and Driver Setup window.
Step 15: Click Connect Telescope in the ASCOM Device Hub window.
Step 16: Telescope State should change to red lettering "Connected" and show positional information below it. On the bottom right side of the window there is a "Rate" drop down menu. Click on this and select 2deg/sec. Press any of the four directions and watch the telescope move under commands from your PC!
Step 17: You might have also noticed that a tall and narrow "EQMOD HEQ5/6" window had opened when you connected to the mount. This is normal and the main "Command Center" for the mount. Slew rates and directions can also be selected from this window. In this window, be sure that "Sidereal" is selected under the "Track Rate" section.
Revenir à « Notices »
